If I read the manual correctly, it says that 5W-30 is "preferred", while 10W-30 is acceptable if the coldest temps are not going below 0*F. There is no negative impact of using 5W-30 year-round. The lower viscosity is only applicable to cold start, and will provide better flow at low temps. On the earlier year engines, the oil requirements are printed on the top of the oil fill cap (mine says "5W-30"). Is that no longer the case?
That said, I always used 10W-30 when my engine was stock, because it never was driven in extremely cold weather. Answer is, it doesn't matter.
