I finally had some time this fall to work on a few little things.
So to follow up. My oil pressure switch/idiot light is still causing me grief. I do have the proper one and most likely the original 3 wire pigtail on the switch. From what I understand the 3 wire are as follows, brown-alt light,green/choke and blue/idiot light. This explanation came from
http://gbodyforum.com/viewtopic.php?f=16&t=25761#.UmUjgPmxeSp but the idiot light does not come on during start up which it is supposed to, I think.
I mean it's beyond my knowledge base and I'll have a professional look at it if I can't figure it out. But it's fun to try. Choke is working yet the the car almost stalls after warm up and will recover. My carb guy thinks there is something floating in the carb. Carb rebuild-I'll add it to the list. I have fixed a few things, door jam switches-corroded and broken-yeh I have interior lights, cleaned the carb and the engine bay, mocked up a air intake hose until I can find a used good one, rerun some new vacuum line, replaced the egr valve, couple of turn signal pigtails installed. My biggest challenge is the fuel filter , the nut is completely stripped and theres no way I can get it off.I may have to cut it. I'm sourcing out a new fuel line but no luck yet. If I can't find one I'll have to bite the bullet and cut the line and put a small rubber section in place. I don't want to do that but I doubt that fuel filter hasn't been change in years. I took it out for a good run today, put some premium gas in it and it feels like it's running much better. Going to see the upholstery shop tomorrow and see what we can do with the drivers seat and the headliner. The interior is in pretty good shape, just the driver seat is bad. Wire frame is collapsed and the seat bun is pretty disintegrated. Passenger side and rear seats are almost perfect.
Theres still a few ghost in the dashboard-turn the wipers on and the signal lights glow. I'm sure it's got everything to do with ground or lack of it.I don't have my headlight switch in properly(lost the bracket somewhere) as well and I doubt it's grounding properly either.. I hope to take few photos tomorrow and add them to my profile.
