Advice needed!!! Comp T/A or Not?
3.3K views 3 replies 3 participants last post by  GetBEnt97
#1 ·
I just inherited a 1997 Comp T/A maybe???? I’ve looked up the vin but not finding much. This is my first toy. Vin:2G2FV22PXV2221410 it has the T56. The engine and trans are out of the car and body has 37000 original miles. Trying to see if I am putting it back together or just selling it. Please help
#2 ·
If its real it's one of 47 built in 1997. You should have a plate near the shifter noting it's a limited edition AND there should be paperwork from SLP. ...call SLP. If it's got the plate stating it's a limited edition, it likely is. However, I've now looked at several and none said Comp T/A on the rear, but the rear badging could have been removed by others or added by the previous owner. Rest of it seems right though.
If SLP built it, they have record of it, and if you didn't get the paperwork they might be able to send a new packet to you for a fair price.
As you're not sure what you want to do, I say sell it. If you wanted the thing, you wouldn't be questioning it's future so let someone with a love for the breed and a desire to have one have a crack at it. ...but realize, that engine is well beyond what SLP did to it which lowers the value even if it was installed AND running. Smart money says that engine is out for a reason, and that reason led the previous owner to pass the problem on instead of repair. Non-runners are non-runners, and custom engines are a jumbo can of worms. I would assume it's not salvageable and needs replaced, and likely with a stock LT1, which makes it a regular Trans Am with stickers, and one that doesn't run on top of that. Literally no value other than as a roller. SLP paperwork might help some here, but forget about "top dollar" even if it ran. It's been molested, and at a minimum, the paint isn't perfect.
If you don't have the plate on the center console, there should at least be glue residue where it was if it existed. No plate, no residue, no paperwork? ...clone. whether it is or not.
You're not finding anything on the VIN because these cars are not OEM modifications, they were pulled from the line, built by a 3rd party, then sent to the dealership for sale. The 3rd party (SLP) has the documentation.
Reactions: 74FormulaFL
#3 ·
SLP sold their business to Roush in 2013. The records for the 4th Gen F-Bodies were retained by one of the original SLP owners, David Hamburger. Dave now owns and operates Specialty Vehicle Engineering, located in the former headquarters of SLP, here in Toms River, NJ. You could try contacting them for info.
Engine is probably far from stock, with the aluminum rocker arms and Canton oil pan. You can find a partial VIN stamped into the back of the block, and also on the transmission. That will tell you if it is “numbers matching”.
There are numerous photos of the 95 thru 97 Comp T/As on the SLP Registry website:
Reactions: 1993TransAm
