1 - 4 of 4 Posts
I started My 2002 Firebird Trans Am Convertible I didn't touch the excalarader It was idling at low RPM for a few minutes and cutoff now it wont start. When I turn ignition to start car the oil pressure gage doesn't move I'm thinking that it may have turned off fuel pump due to low oil Pressure if so is there an easy way to correct this I don't want to start randomly jumping out relays
Based on a quick scan of the engine and fuel system control schematics in the factory service manual, I don't see any input to the PCM for oil pressure, nor any electrical oil pressure interlock in the fuel pump circuit. If it's there I missed it. The earlier 4th Gens did not interlock engine starting with oil pressure.
There is PCM input from the oil level switch. Have you checked the oil level?
Have you scanned it for codes?
sorry I have been so busy with work I haven't had tine to look at it ill check the oil pressure
switch thanks
1 - 4 of 4 Posts
