Getting a crunch crunch crunch when operating my window. Looks loke someone has replaced it at somepoint by the cutouts. Teeth on regulator look ok. Is it most likely the motor?
I stand corrected! Thanks!From the factory, the motor is riveted in.
Review the Shoebox procedure. Drilling holes in the outer panel is the routine method to access and drill out the rivets mounting the motor, then bolting the new motor to the regulator.
I was simply responding to post #2, which incorrectly indicated the motor was bolted to the fiberglass inner panel and had torn the bolts out of the fiberglass panel, and the panel needed to be replaced.
