Greetings, This spring I stripped the interior out of my 81 TA to sound deaden it only to find the passenger side floor pan rusted out,UGH...... Well got a new pan and had the whole passenger side replaced.
I assumed the rust out was due to leaking T-top seals as its common. We had a pretty good rain today and I put plastic under the t-top and over the glass taping the perimeter to the glass and body. Went out and water in the floor. Started looking around under dash and the insulation behind the heater enclosure is wet and I saw a drop of water drop down.
I had a guy replace the heater core some time back and I'm wondering is there some type of sealer that should be between the box and firewall or is there is something above that in cowl that I'm missing? I checked the exit where heater core goes into engine compartment and the material around the hoses is broken so I plan to seal those. any other ideas?
I did pull the kick panel with vacuum chamber for ac when I pulled interior. Is it possible that somehow it has left the cowl flap open or would this make a difference. Would seem that you would use vent when it rains on occasion. Any help would be appreciated.
