I discovered I have water in the the ATF.
I have just replaced the radiator and I am confident this radiator was the problem of water in ATF also.
The car has maybe 1/2 to 1 mile in this condition.
Has sat idling approx. 2-3 hours working on other items.
Anyways, I have dropped the pan, cleaned and it is draining over night. Doing new filter of course.
Now I realize at least 1/2 or more of the fluid in the Torque Converter.
What are your opinions next step? :
A. - Dont put filter on, run the car around the block and drain again? repeat until full red ATF is observed ?
B. - Disconnect cooler line hose and drain this way instead? run at idle in neutral for couple minutes draining then top off again? doing this intermittently until ATF is 100% red observed?? (run w/ filter to catch impurities and then replace with another new one)
I know I know... A lot of people have said do not run at all and rebuild now right away!
Thoughts please. Buttoning up the tranny pan this weekend.
