Have 69 Firebird 350 w/400 auto Tran & A/c and needed to replace dash bulbs. Printed circut bd was bad so replaced it. Now have great dash lites but no Brake warning, oil, temp lite. Alt lite comes on and pulsates w/ rpm of engine! Checked all the bulbs and have new ign switch. Dash lites all work even the fiber optic to the ashtray. (was not hooked up at the factory but works now) The oil, Alt, & temp lites all worked normal before the circuit board change.
I am not a tech so am at wits end.. The reason for the E Brake warning lite failure was the speedo cable had over life of the car had dripped some fluid on the bulb socket for the brake lite that is located under the speedo cable conn. this seemed to ruin the circuit board over time and brake lite quit working about a year ago. Am sorta afraid to drive car with the alt lite pulsating!. Don.t want to take dash apart again to replace bulbs or start a fire! What should I look at to start correction of this prob.? Thanks for your help and suggestions. F Woodard
