After a new set of wires, new spark plugs, new cap and rotor, new 140 amp alternator, triple checked firing order..... I am not able to get my car started.
I confimed i am getting voltage to the ignition wire. I also checked if my distributor was set correctly. After getting #1 to TDC, the rotor was way off (see pic).
Also, my timing marks are off on the balancer.
How do I go about getting timing lined up at zero mark. Its cranking over and backfiring on occasion but wont start. Any ideas? Am I off on where I set distributor?? (Rotor pointing to number 1 cylinder at TDC).
Do I possibly have the rotor screwed on backwards? Sorry for all the dumb questions, I'm very green.
Pic attached is prior to me adjusting, I pulled distributor and set it pointing towards #1 now, and still wont fire. I'm out of ideas.
