my temp gauge isn’t responding, i put my key in and turn it to acc on and even then my temp gauge doesn’t move at all i don’t know what to do any tips ? all my temp sensors seem good but my gauge isn’t moving at all
honestly i forgot i made that last postJust realized, I already responded to your earlier post about the same problem? Any reason you didn’t respond to that post?
temp gage not working and o2 sensor location
hey guys so this a double trouble typa situation first my temp gage isn’t moving and i’m getting no temp it’s at 160 also where are all three o2 sensor locations ?www.firebirdnation.com
do you have any suggestions on what dvm i should buy that won’t mess up my car ?Test procedure:
Scroll down past the resistance chart.
Could be as simple as the wire/harness falling off the sensor in the driver side head, between #1 and #3 spark plugs.
no no i know the process on how to text it i’m asking what brand and model of dmm you’d recommendRead the first paragraph in the link I gave you. That covers the DVM and resistance measurements. The procedure for measuring volts is covered further down on the that page. The device is probably more accurately described as a “digital multimeter” (DMM).
