I get that the front springs and control arm bushings should be replaced first. This will get the front of the car level. Then the rear frame rails should be replaced and any rear leaf spring bushings, sway bushings next. Now that everything is back to "stock'. Put in the sub frame connectors to tie the back of the car to the front.
Your choice of front coil springs is crucial. There are a million different ones to choose from because there were so many different car and engine combos available over the years. ie., big engine, no A/C , small engine with A/C, etc. and every other combo.
If you want to go factory style, duplicating the 78 WS6 suspension is a pretty good bet. You can get those spring from Moog. The part no. is 8002. Those will be really great if you have that basic combo, a heavy late seventies TA with a 400 with A/C. Or you can go after market. I just bought some springs from H-O Racing. Part numberSB43 . They are designed for 560lbs. ,designed for a 3900 lb, TA cost $179-. They are made just specially for H-O Racing for them The wire diameter is 7.5 -in dia. (Can't wait to get them installed.!!!!) That is a really big diameter which means they are really strong. Most "car"springs are around .670 " diamater. There is one spring that was actually for Chevy pick up trucks that a lot of people like. The Moog number is 6450. The diameter is .828 inches and they are rated at 406 lbs. You can spend hours on this stuff. Hotchkis makes them too.
I'm looking forward to installing my new Hotchkis subframe connectors. They cost about $300 with new bushings and are the ones used on the Year One Burt Reynolds Trans Ams.
