Need help with the steering column... So I had my 78 formula at a frame shop to replace the sub frame with a straight 76 formula sub frame. When I got it back it would not shift in all gears... after a lot of stress we found out once the rod linkage is un-pinned from steering column everything works. After further inspection I can see the Steering Column inside the car is knocked to the left and there is a huge gap on the right side between the column and the dash bezel. Can i adjust this some how and maybe it will align with the rods again and work like it should? Thanks!
