Hi all. I’m looking to replace the speedo wire since the needle is jumping all over the place. I can’t find a diagram that specifically shows where it goes and color. Anyone have one?
Oh! I didn’t know you couldYou will get better results with topics like this if you add your vehicle information to your ”profile”. The info will appear in your post, on the left hand side right below your avatar and member name. That way people can see year/engine/etc. about the car, so they don’t have to ask.
Click on your avatar in the upper right corner of any screen. On the drop down select “Account Settings“, scroll down and complete “Vehicle Details”.
In the meantime - what year is the vehicle you are asking about? Older models use a cable to drive the speedo, newer models use wired vehicle speed sensors. We can assume it’s an 81, but let’s be sure.
Yea sir it is. That worksIs your car equipped with cruise by chance?
I have a Hayes, manual, and the schematic for the engine harness and the dash harness that I found in this forum. And I don’t really see anything other than a tachometer.What factory repair manuals do you have, if any?
Thanks Brian! It does need a new gear box. Would that be something that might help?You’ll have two cables with cruise. A lower, from trans to the cruise control transducer which is mounted on the drivers side inner fender in the engine compartment. Then from the transducer to the speedometer is the upper cable.
First thing I’d do is check the routing of the cable. Poor routing caused mine to jump also which I believe is mainly from bends that are too sharp. Next thing I’d consider is remove the cable from the transmission end and use a drill to turn the end counterclockwise to see if the speedometer still bounces. If not, the speedometer gears in the transmission could be the culprit. If it does, I’d remove the upper cable from the transducer and use a drill again. If it still bounces you’ll know it’s either that cable or possibly (but less likely) the speedo. If it doesn’t bounce it is either the lower cable or the transducer.
