1 - 20 of 22 Posts
· Old and Slow
I've tried with several different scanners and they all say the same thing.
I've checked my grounds but I'm going to check them again. My SES light is on and the car runs but i can't scan for DTCs and I can't collect any data for tuning purposes.
Any ideas?
Hi Russ,
I think you post a topic in wich you said that you were changing the LT1 motor for a LS1. Is this is the same car?
Ivan
· Old and Slow
Hi Russ,
Ivan
No Ivan. My mods are in my signature.
I had posted about the LS1 swap before but decided against it.
Russ,
Try checking for a open (ohms) cable(s) in the harness from the OBD port to the ECM.
Ivan
· Old and Slow
Russ,
Ivan
I checked both grounds, verified 12 volts and verified continuity at the data wire from the PCM to the ALDL port.
Russ Sorry but, have u checked fuses? Something like the cig lighter fuse supplies the power to the OBD connector too.
Actually only 1.5 cents with the economy today.
· Old and Slow
Yes, I checked all the fuses and I'm getting 12 volts to the ALDL port.
Have you tried a different PCM? I hope that isn't what it is, but options are running out.
· Old and Slow
Discussion Starter · #9 ·
I've got an un-tuned PCM out of a 96 Camaro LT1 A4. I guess it wouldn't hurt to hook it up just to see if it connects.
Yes, also there are shops that can check PCM functionality.
Ivan
· Administrator
What PCM do you have in there now?
· Old and Slow
Discussion Starter · #12 ·
I have the PCM and harness that was in my car originally. It was tuned by Madtuner for my mods except for AIR delete. The engine is out of a 95 so it doesn't have a crankshaft position sensor. I did install the EVAP solenoid and a 96 Knock Sensor.
· Administrator
Did you figure this one out? I've been trying to think of why its not connecting. But if the cig lighter fuse is OK, you are using the 96's OBD-II PCM, you are using an OBD-II scanner, and you have the correctly wired 96 ALDL connector, it should connect.
· Old and Slow
Discussion Starter · #14 ·
I haven't figured it out yet Fred. I'll be sure to update when I figure it out.
Russ, are any of the pins in the ALDL connector pushed, eg. in to far where they won't make contact? Can u see all the metal tabs recessed the same distance from the face of the plug? Just a thought.
· Administrator
Another thing I thought of, but I doubt it applies here - I have a ScanMaster LT1 mounted on my dash, and hooked up permanently to the ALDL connector, by splicing to the tan data wire, behind the ALDL connector. I had to add a micro-switch, to allow me to disconnect the ScanMaster from the data wire, because when it is connected, it will not allow another device (e.g. scanner, laptop scanner or programming software) to connect by plugging into the ALDL connector. Any chance you have something connected to the data wire?
· Old and Slow
Discussion Starter · #17 ·
Another good idea Fred, but the ALDL and all connections are original.
· Old and Slow
You can move this one to "Resolved" Bob.
Stupid me!
I stumbled across the cause of the problem. I had three PCMs in my garage and somehow got them mied up. The reason scanners couldn't read the DTCs is because I had put the PCM out of the 95 Firehawk A4 in my car.
Put this one in the "Dumbest things I've done" thread.
Here's what happened. During the time I was swapping engines, I ended up with 3 PCMs. One was my original(OBD2), one was out of the 95 Firehawk(OBD1) that I parted out and a 3rd one. I had marked each of them, but, somehow I switched the 96 with the 95 and installed it in my car.
I discovered this when trying out the other PCMs to see if the one in the car was fried. The car ran better and I checked the service numbers and Voilla!
All the pieces of the puzzle fell together after that. The high idle, running rich, the ALDL port not working, etc.
It ran pretty good before other than a high idle and running rich but it really runs good now!
Reactions: FBN Firebird Nation
1 - 20 of 22 Posts
