Hi all. My drivers door is sagging badly, the lower hinge pin has worn way through the bushing and gone oval.
I would like to get the doors aligned before commencing on the body prep for paint to make sure all the body swages and shut-lines are correct. I know it will mean dropping the doors twice (again when paint applied) bit the paint has to be 100%
Can I ask your opinion as to re-manufactured hinges vs original? There is so many things wrong with mine;
LHS top - missing spring, roller and bushes
LHS bottom - missing bushes, oval holes
RHS top - missing spring and roller
RHS bottom - OK actually!
I figured on getting a set of 4 new hinges from D&R (the postage is the same to the UK as a pin set!) Then I read that aligning was way worse than swapping he springs and bushes. What do you think? I watched the Youtube video of the guy compressing a wonky spring in a bench vice and it made me squirm!
