Hi Guys- I inherited a 1979 10th Anniversary Trans Am with 22K with the 403 Olds engine, I replaced the entire fuel system and tank, also rebuilt the original carburetor I also replaced the ignition except for the coil pickup, car runs great but lately has had idle problems, I replaced the EGR valve and it fixed the problem.
Now after about two months I'm having the same idling problems so I thought maybe the EGR valve went bad, I changed it and I still have the same problem, I saw that the EGR valve connects to an EGR control valve (which I would love to know what it does and why is it mounted where it is) I was going to replace it but can't find a replacement so I blocked off the vacuum at the carburetor with no luck, I also noticed that there was no vacuum at the carburetor, is that normal?
Any suggestions would be greatly appreciated. Please ask any questions and thank you in advance. RON.
