In my time trying to make my Firebirds correct with factory pieces, I have found that the topic of Rochester carburetors PN stamping(s) to be a large issue.
One side the issue is how to tell if what I have (or run across) is a Factory OEM proper stamp numbers VS re-stamp ones.
The scam of people whom grind PN off & re-stamp PN of a rare unit is the core concern.
One aspect is I "somebody replied in a forum" saying that the Pontiac RA type pieces were all stamped by Rochester ONLY, not carter MFG.
I have no way to verify this one important point.
Another concern is in this whole topic, Why have I seen plenty of RA PN stamped carbs with different style PN die impressions on them, Heavy or narrow print stamp?
And different direction numbers were stamped out also (top to bottom VS Bottom to top direction) .
The values of one unit for my car on several different sources is Between $895 and some over $1,000 for it
I actually seen some units priced high as $4,500.00 for certain car applications.
So, how can it be proven with certainty of an OEM unit VS a very well disguised and in reality is just a
re-stamp piece?.
A Rochester is a Rochester, you seen one you seen them all, in my opinion , they can be a great performer with tuning and knowledge how to.
I have one w PN 7028273 which would make it very valuable on the market place yet it appears to be a re-stamp.
Any wisdom and sources to add light to this topic tis appreciated.
Thx
Rob
re-stamp piece?.
Thx
Rob
