1 - 8 of 8 Posts
New member here working on a 96 trans am LT1 engine. I've been rebuilding the top end of my engine this winter and have rebuilt the fuel injectors. After putting on the new rings, baskets and spacers, I put the injectors back on the rail and had all kinds of difficulty getting the fuel injector clips to slide back over the injector.
I had to really work at it, but finally got them all under the clip. When I put them back in the intake and bolted them down, I couldn't get the injector electrical plugs to fit back down on about half of them. They just wouldn't go back down enough to lock on. So I disassembled again, and even tried using the old rings to get the injectors to fit in deeper.
I put on the intake again, and still couldn't get the plug to engage on 5 and 1 on the drivers side. I haven't even tried the passenger side yet. It looks like the fuel injector clips are blocking the plug from seating like it should.
Anyone else have this problem and find a way to cure? Any help would be much appreciated
Are you sure you got all the old o-rings out of the intake manifold and fuel rails? Did you put a bit of oil on the o-rings to ease the insertion? Did you verify the dimensions of the new spacers?
Yes. I've cleaned the intake holes and oiled the O-rings. All the O-rings new and old look the same, both tops and bottoms. The new ones look a tad thicker, but still can't get the plugs on the ones with the old O-rings. It looks like the fuel injector metal clip is what is preventing the plug from going on. When one slide off the fuel injector when I was inserting the plug, the plug engaged like it should.
You have the retainer clips slid into the injectors from the front (of engine) side, correct? Not pushed over the injector from the connector side. I can't check mine because I don't use the clips with my Bosch injectors.
I believe I've tried them both ways. But, I'm going to try that tomorrow. I didn't notice a big difference in clearance for the plug. You can imagine how long it took me to put the air conditioning system back in. I had to try everything about 5 times to finally get it right.
The only part of the clip you should see is the little "curl" that wraps upward over the lip on the edge of the fuel rail.
Discussion Starter · #8 ·
I did the fuel injectors on my 90 a while back. If not careful and install the retainers the incorrect way, the electrical connectors do not fit on all the way.
Do you remember if the c clip slide on in the same direction for each injector on each side? The clips are c shaped so do they slide on with the inner c pointing towards the back of the engine or the front of the engine. This will reverse which side of the injector that the clip will slide on.
1 - 8 of 8 Posts
