Hello All,
I am planning on building a 400/ zero deck that is stout. I am using the Turbo 400 tranny and have 3;55 rear end gears on a 70 firebird. I am planning on using 6x heads with a static compression of around 8.7. I assume I would need to find some flat top pistons. has anyone tried this cam or can recommend it as I dont plan to do 100 mph or can recommend something that will provide great midrange response and still have vacuum at idle
Thanks
Chuck
Voodoo Hydraulic Flat Tappet Cam & Lifter Kit - Pontiac V8 262/268
Product Description
Lunati's Voodoo series of Hydraulic camshafts deliver more area under the curve than any other series of Hydraulic camshafts. This means more throttle response, quicker acceleration, more vacuum, better efficiency, combined with maximum horsepower and torque!Hydraulic Flat Tappet Cam. Torque Monster for 400-455 c.i. daily driven street performance vehicle. Excellent torque and horsepower production with heavier emphasis on the low to mid range. Will work in tri-power applications with larger 389-455 c.i. engines. Choppy idle!
Part Number: 10510702LK
Previoius Part Number: 60902LK
Thanks
Chuck
Product Description
- Advertised Duration (Int/Exh): 262/268
- Duration @ .050 (Int/Exh): 219/227
- Gross Valve Lift (Int/Exh): .468/.489
- LSA/ICL: 112/108
- Valve Lash (Int/Exh): Hyd/Hyd
- RPM Range: 1300-5500
- Includes: Cam & Lifters (#71951PR-16)
