1 - 3 of 3 Posts
On the 67 can you just remove the plain gauges and install rally gauges or is the wiring different?
I realize the sending units need to be changed
I know on a lot of older GM you can just swap cluster types like that
Sorry but the dash wiring harness is different as is the printed circuit pigtail that plugs into it so no .
There are some that have rewired to make it work you have to add wires and change the pins around
1 - 3 of 3 Posts
