1 - 1 of 1 Posts
Need help with radiator, it's a Aluminum 3 core w/ dual fans.
My problem is it's leaking transmission fluid from the bottom of right side tank. Both the AT lines are in tight and don't seem to be leaking, it seems to be coming from the bottom radiator hose or connection?
I have attached some photos, I'm confused why it's leaking at the point. I was think it had a hair line crack in bottom of tank so I used JB weld to see if this would solve the problem, Nope!
Please any suggestions would be appreciated, don't really want to pull it out and start over. . . Any ideas?
Hand Automotive lighting Hood Automotive tire Idiophone
Tire Automotive tire Hood Motor vehicle Automotive design
Automotive lighting Hood Automotive tire Grille Motor vehicle
Automotive lighting Hood Motor vehicle Bumper Automotive exterior
1 - 1 of 1 Posts
