1 - 7 of 7 Posts
Does anyone have a idea y my firebird could be overheating? I’ve replaced the radiator an thermostat all the hoses are fine hard lines plugged in, bled the radiator after I put new coolant in and it still overheating. This the last pic I took before it hit 260 an went up in smoke
Asphalt Font Road surface Circle Measuring instrument
DELCO NERD
Which model year and engine are we talking about here?
Under what conditions do you experience the above overheating - at idle, during local part throttle driving, at freeway speeds under part or heavy throttle?
What is the coolant mixture?
When you open the radiator cap after a high temp event, is the coolant full, to the top of the fill neck?
Do you have the correct LT1-specific thermostat? What temperature?
Is the engine modified in any way? Stock program or reprogrammed PCM?
Manual or auto trans?
Is A/C functional?
Have you verified fan operation. A 94 can have two different fan strategies - early production: 2 relays, fan #1 on at 226°F, fan #2 on at 235°F. Or - late production: 3 relays, both fans on low speed at 226°F, both fans on high speed at 235°F.
Have you scanned the PCM for codes? There are codes for the coolant temp sensor in the water pump housing, and for the fan relay signal circuits.
Any signs of a blown head gasket?
No ac, auto trans, no codes no engine mods, the fans don’t cut on due to wiring, the thermostat is set at 180, the coolant is the a mix of water an coolant.
Are you saying the fans aren't working at all, or are you indicating the fans are controlled by some aftermarket device?
DELCO NERD
I would have to think that if the fans aren't functioning properly, there would be a pretty good chance of the engine overheating.
1 - 7 of 7 Posts
