1 - 10 of 10 Posts
shutzero
Discussion starter · #1 ·
i noticed some drops of oil under my car after i parked it for a few hours and i was wondering if anyone else had an oil leak and if you knew where it was coming from. i noticed some oil around the valve covers... any help?
possible u have a leak from the cover or manifold gaskets. wheres it dripping at on the floor, front or rear of car?
Discussion starter · #3 ·
dripping from the front right under the oil pan...and it looks like it might be coming from the bolt on the oil pan...but i just replaced the bolt so idk maybe i didnt tighten it enough? cuz i thought i tightened it pretty well
Is this a bolt or nut on the oil pan? If so, you probably overtightened it as they don't require very much torqued, and if you over torque it, you will break them. Did this show up after you tightened it?
How many miles u got??? ne more than 75,000 Hell Naw
Matt
1 - 10 of 10 Posts
