Hello
I replaced the steering column in my car and now have a no start condition . Before I start digging, I figure I will post here and wait a day.
lets forget the column was replaced for now.
All contacts were sprayed with contact cleaner before reassembly
I used the same ignition switch ( electrical) which has 2 plugs and the actuator moves freely and was disconnected from the key for test operation. I did have another switch and tried it as well with the same results.Also connected a flat ribbon cable
ground.
There is a small wire that gets grounded to the column plate that gets unbolted to drop the column.
is there anything else I should check or may of forgotten?
the car is pretty much gutted.
Neutral Safety Switch has been shorted and column sleeve has been adjusted.
Thanks
Chuck
ground.
Thanks
Chuck
