1 - 4 of 4 Posts
1977 Trans Am W72 400/4speed (swapped)
I’m not as familiar with 1st gens but I believe it is a similar design to 2nd gens and in that case, no you don’t have to remove the console. In a nutshell, under the car, there is a linkage attached to the transmission that is linked to the steering column. There’s a collar on the column that rotates as the console shifter is moved through the gears. That collar manipulates the neutral safety switch.
1 - 4 of 4 Posts
