First, make sure there is no CD jammed in the player or upside down. Then, try resetting the unit by disconnecting the battery for a few minutes and then reconnecting it.
E23 is supposed to indicate a problem with communication between the radio and the internal CD drive. If it continues after disconnecting the battery, the unit may have a defective CD drive. There is a red cable between the two parts and you can check that by opening the radio, but it is not very likely the problem. If you decide to take it apart, be very careful removing the front panel; it is not hard but is tricky to do without breaking the tabs.
I had a similar condition once (forgot the code), As a last resort, I took apart the CD drive to look for anything wrong. There was something jammed in the mechanism, and I was able to free it up. But I can't tell you the details because I was just trying a bunch of things and don't know what I really did.
Related Threads
Firebird Nation
647.1K posts
38.7K members
Since 2004
