Ok so, I have a 99 3800 (automatic) bird and something is up
A while back I had to jump the car and my buddy didn't know how to jump a car so while jumping it I blew a couple of fuses
one of the fuses was the one that controls the speedometer, and for the drive to Walmart for new fuses it kicked like a raging mule when it shifted
Got the fuses fixed for the speedometer and a few others and now I'm left with this
-As the car shifts from 1st gear to 2nd it kicks- not like a bunch of little kicks but one good buck while shifting
-Car has a rough idle- randomly jumping rpm while parked
-Going up hills in lower gears it makes a loping noise where the engine will sound like its under load then quiet then back under load
-Poor fuel economy
For the first week or so after getting the fuses replaced it threw a code and this is what info the scan got me (will post image of paper in response to this post)
Essentially the guys at AutoZone who printed out the paper thought that code was like the funniest thing ever because it says it is either the cat or literally a broken check engine light
But for a while its still been bucking and doing all the things I said above and I'm just wondering this;
Is it a misfire, or is it the trans going out?
I know the automatic transmissions start to show their age in the later parts of the 100k mile range and I'm sitting at 111,000, or do you think it may have something to do with the speed sensor? I sorta just guessed it was a misfire because all those symptoms are really common with misfires but it'd need to be pretty coincidental timing to have it start misfiring right after a jump that knocked out my speedometer.
My current guess is that its a misfire, but I'm mostly asking because it may be something I haven't heard of that could be a fuse or something electrical related to telling the trans when to shift.
Thanks for the help guys and let me know what you think
-Poor fuel economy
