FBN Pontiac Firebird Tech Article Index
Tip: press ctrl and f at the same time on your keyboard to search this document.
Here is a list of our 4th Gen Tech Articles, How to's, electrical diagrams, troubleshooting, and more.
Find a broken link? Please report all broken links to Formula71.
Engine Specific:
V6
General Engine:
1. 3.4L Firing Order and Coil Terminal Locations
2. 3.4 / 3.8 L V6 to LT1 / LS1 engine swaps
Troubleshooting:
1. Engine Cranks But Will Not Run - V6 Submitted By Bob
2. Fuel System Diagnosis 3.4L V6 Submitted by Bob
PCM and Sensors:
1. 3.4L Sensor Location Map - Submitted by Bob
2. 3.4L 3800 V6 Knock Sensor Location and Replacement
3. 3.4L 3800 v6 Oxygen Sensor Locations - submitted by Drew
4. Fuel Pump Circuit (Low Voltage) With Schematic 3.4 L V6
LT1
Engine Cooling Systems:
1. LT1 Engine Cooling System Sensors - Written by Bob
Exhaust:
1. LT1 Shorty Header Install - Written by Bob
General Engine:
1. Basics of the LT1 engine - Submitted by Bob
2. 4th Gen LT1 Spark Plug Replacement - Written by Bob
3. Vacuum Leaks and the LT1 - Written by Charles
4. LT1 Performance Bolt On Guide - Written by Bob
5. LT-1 Ignition System - Getting to know the Opti-Spark
Troubleshooting:
1. Engine Cranks But Will Not Start Flowchart 5.7 L V8 - Submitted by Bob
2. LT-1 Scanning Guide - Written by Injuneer
LS1
Drivetrain:
1. 4th Gen Clutch Removal and Installation (LS1) - Written by Jason Painter
General Engine:
1. Free Air - Home Grown Ram Air for the LS1
Non-Engine Specific
General:
1. RPO Code List - Provided by Crispy
2. 1994, 1996, 1998, 2000 Factory Manuals - Provided by Gary
3. 1998 - 2002 Parts Diagrams - Provided by Gary
4. 1999 - 2002 Wiring Diagrams - Provided by Gary
How to read electrical diagrams
ABS and Brake System:
1. Fourth Gen Pontiac Firebird ABS Component Locations
Audio:
1. Typical 4th Gen Pontiac Firebird Audio Wiring Diagram
2. Unlock Your Radio and resetting theft lock on a Fourth Gen Pontiac Firebird - Written by Simon
Drivetrain:
Clutch:
1. Clutch Bleeding Procedure on a Fourth Gen Pontiac Firebird - Written by Bob
Transmission:
1. Making Your Tranny Have A First Gear - Written by Owen
2. Transmission Assembly Removal, A how to Article - Written By Bob
3. Skip Shift Delete Free Mod - Written by Fred (Injuneer)
4. 5 Speed to 6 Speed Swap Written by Fred
5. Control Valve Removal and Installation - Submitted by Bob
6. 4L60-E Operation and Diagnosis Part 1 - Right Click Save As (Large File)
7. 4L60-E Operation and Diagnosis Part 2 - Right Click Save As (Large File)
Rear End:
1. Moser Axles and Drilled and Slotted rotors install - Written by Russ
2. Rear Wheel Bearing R&R Written by Barber
3. 1993-2002 Pontiac Firebird Rear Axle and Transmission Guide - Written by Dustin
DTC's:
1. DTC 16 With Flowchart - Submitted by Bob
2. DTC 36 With Flowchart - Submitted by Bob
3. DTC 42 With Flowchart - Submitted by Bob
4. DTC 66 Brake - Submitted by Bob
5. DTC PO300 Diagnosis - Submitted by Jason
6. DTC 1441 Diagnosis - Response by Fred
Electrical Systems:
1. 4th Gen Starter and Starter Circuit Diagnosis - Written by Bob
2. 94 Headlight Wiring Diagram - Submitted by Bob
3. Keyless Remote Entry Wiring Diagram - Submitted by Bob
4. Keyless Remote Receiver Location - Submitted by Bob
5. Turn Signal And Cruise Control Lever Assembly Removal and Installation. - Submitted by Bob
6. 4th Gen Power Window Troubleshooting - Submitted by Ivan
7. Horn Location
8. Cruise Control Module Location
9. Discriminating Sensor Forward Location
10. Underhood Electrical Center Location
11. Turn Signal Switch Removal
12. Disabling and Enabling SIR
13. Remove Steering Column Coil Assembly, Shaft Lock, and More
14. Steering Wheel Locking Housing Cover, Pivot and Pulse Assembly, Dimmer Switch Rod Actuator, Tilt Spring Assembly
15. Daytime Running Lights Module Location
16. How to troubleshoot blinker problems - Written by Larry
17. Headlight Switch Modification - Wanna leave your headlights up?
18. How to Bypass VATS Security in a 4th Gen Firebird - Written by Joe
19. BCM Removal & Repair - Written by Gary
20. 1999-2002 Wiring Diagrams - Provided by Gary
21. 3rd and 4th gen light socket repair - Written by Matt (mytmouse)
22. 4th Gen Firebird Headlight Controller Module - Written by Gary Doug
1. Electrical Fans Troubleshooting and Flow Charts - Submitted by Bob
Emissions:
1. EVAP Diagrams - Submitted by Bob
Exhaust:
1. 4th Gen Long Tube Header Install - Written by Jens
2. JBA Header Install - Link to Fred's Tech Article
Exterior:
Lights:
1. 4th Gen Taillight Conversion And Replacement - Written by Kev
2. 4th Gen 93 to 97 Fog Light Installation - Written by Denise Carrizales PDF FILE
3. Headlamp door operation, diagnosis, and repair
4. Headlamp Door Module Location
5. Changing Headlights on a 4th Gen Firebird - Written by Jim
6. 4th Gen Headlight Issues - External link that should help you fix any and all 4th gen headlight issues.
7. Fog Light Installation
Other:
1. Front bumper removal and installation
2. Rear Spoiler Exploded View With Center Taillight Wiring - Submitted by Bob
3. Rear Decklid Panel Removal and Exploded View - Submitted by Bob
4. 4th Gen Firebird Wiper Arm, Cowl Panel Disassembly - Submitted by Bob
5. Install 2nd Gen TA Hood Decal on a 4th Gen - High Performance Pontiac article
6. CETA Appearance Rear Bumper - Submitted by ~chipsahoy~
HVAC:
1. HVAC Vacuum Diagrams - Posted by Bob
2. Heater Hose Replacement - Posted by Bob
3. Air Conditioning Components Identification - Submitted by Bob
Fuel Injection (also see general engine):
1. How To Check For Leaking Fuel Injectors - Written by Bob
2. Fuel Pump Relay Diagnosis and Troubleshooting and Component Diagrams. - Submitted by Bob
3. Fuel Pump Relay Location
4. Fuel Pump Check in a Nutshell - The quick guide to checking your fuel pressure by Fred
5. In Depth Fuel Injection Check Firebird and Camaro
General Engine:
1. Opti-Spark (Distributor) and Water pump Replacement - Written by Bob and Charles
2. Bleeding the cooling system - Written by Charles
3. 4th Gen Rear Main Seal Replacement - Written by Bob
4. Dual Remote Oil Filter Modification - Written by Dave Dorey
5. $6.00 15 Minute Ram Air Intake Mod - By Russ and Injuneer
6. Oil Pan Removal and Installation
Ignition:
1. Troubleshooting the coil - Submitted by Bob
2. Troubleshooting the Ignition System - Submitted by Bob
Interior:
1. Budget Interior Customization - Written by Owen
2. How to replace the ignition switch assembly - Submitted by Bob
3. Disabling the SIR system - Submitted by Bob
4. Enabling the SIR system - Submitted by Bob
5. Window motor replacement for Camaro and Firebird. This is the easy method!!! - Quickly remove your 4th gen Firebird or Camaro Window motor with this easy method complete with photos. Written and photos by Bob for you!
6. Window Motor Replacement for Camaro and Firebird Part 1 - The Removal. - Written by Bob
7. Window Motor Replacement for Camaro and Firebird Part 2 - The Install. - Written by Bob
8. Door Panel Removal and Installation for Camaro and Firebird - Written by Bob
9. Changing The Color Of The Interior Plastic/Vinyl
10. Door Exploded View, Door Lock Actuator, Striker Assembly, and Lock Cylinder Unit - Submitted by Bob
11. Dealing with Sagging Doors - Submitted by Leon, Doc & Lou
12. Keyless Entry Module Wiring Diagram
13. Cracked / Split Dash Repair Guide - Submitted by Vlady
PCM and Sensors:
1. Sensor Maps - Written by Bob
2. LT4 Knock Module Install, My Guide to install the Module - Written by Mike
3. How To: Flash PCM - Written by Steve
4. How To Test Your MAF - Written by Bob
5. How To Test Throttle Position Sensor (TPS) and Circuit - Written by Bob ***Be sure to also see Fred's post directly after the linked post.
6. How To Test and Remove/Install Crankshaft Position Sensor CKP - Submitted by Bob
7. 1997 Crankshaft Position Sensor Removal and Installation - Submitted by Miles
8. SCANNER READINGS - WHAT DO THEY MEAN? - External Link To Injuneer's Excellent Writeup
9. How to Reset the Change Oil Light - Written by Jim
9. Free PCM Scan Programs
10. Camshaft Position Sensor, location and replacement.
11. Supplemental Inflatable Restraint System (Air Bag) Wiring Diagrams
12. Idle Air Control Valve (IAC) adjustment and resetting procedure
13. 1995 ODB2 Connector with ODB1 PCM
ECM:
1. ECM Broadcast Codes 1981-1997 - Submitted by Sea Dog
Modifications:
1. Throttle Body Bypass Modification - Written by Kevin.
2. 4th Gen "Ram-Air" Mod, Works on V6 and V8 Models - Written by Joe - Joesperformance
3. Running NOS Safely
Suspension:
1. Installing SLP's Bolt-On Subframe Connectors - Written by PBFred
2. Exploded View of Steering Wheel Column and Parts
3. 4th Gen Tilt Wheel Repair - Submitted by Bob
4. Hal Shock Install With Eibach Springs - Link to Fred's Tech Article
5. Strange 12 Bolt Install - Link to Fred's Tech Article
6. Rear Shock Removal and Install - Submitted by Bob
7. Rim Fitment and Backspacing for 4th Gens
Radio/Stereo/Audio/CD Player:
1. Stereo Wiring Diagram - Submitted by Bob
2. Basic Radio Wiring Diagram (Non-CD or Tape) - Submitted by Bob
3. Steering Wheel Audio Control Wiring Diagram - Submitted by Bob
4. How to Install A New Radio Into Your Early 4th Gen.
5. Installing 6x9 Speakers
Theft Deterrent Security System:
1. Theft Deterrent System Component Locations Location of the Theft Deterrent Module, Daylight Running Module, Diagnostic Energy Reserve Module, Turn Flasher. Also See Troubleshooting Below.
2. Theft Deterrent / Security System Guide - You will find all the information regarding the theft deterrent / security system here including component location, troubleshooting flow charts, and much more.
Troubleshooting:
1. 1993 to 1998 Trouble Shooting Guide - Written by Bob, Under Construction
2. Instrument Cluster Fuel Gauge Schematics
3. Engine Cranks But Won't Start, Security Indicator Lamp Illuminates For Five Seconds And Then Goes Out
4. Theft Deterrent Module Location
4th Gen Owners Manuals:
1993 Firebird Owners Manual
1994 Firebird Owners manual
1995 Firebird Owners Manual
1996 Firebird Owners Manual
1997 Firebird Owners Manual
1998 Firebird Owners Manual
1999 Firebird Owners Manual
2000 Firebird Owners Manual
2001 Firebird Owners Manual
2002 Firebird Owners Manual
Engine Specific:
V6
General Engine:
Troubleshooting:
PCM and Sensors:
LT1
Exhaust:
General Engine:
Troubleshooting:
LS1
Drivetrain:
General Engine:
Non-Engine Specific
General:
Audio:
Drivetrain:
Clutch:
Transmission:
Rear End:
DTC's:
Electrical Systems:
7. Horn Location
Emissions:
Exhaust:
Exterior:
Lights:
Other:
HVAC:
General Engine:
Ignition:
Interior:
PCM and Sensors:
ECM:
Modifications:
Suspension:
Troubleshooting:
