1 - 2 of 2 Posts
Looking for suggestions for a good set of tires for my 72 formula 400 with 15 inch honeycomb rims. I also just overhauled the entire suspension except for the springs. Is it worth having the factory leaf springs reconditioned? If not who makes a good set? Another thing I am lost on is the coil springs. I am confused on what # I need. I read the originals are around 325 and it seems like a lot of guys are upgrading to the stiffer ones between 550 and 600lb. Any help would be greatly appreciated. This is my first build and it is getting a little overwhelming!
For tires, I like white letters, at a reasonable price. So, I'll go with the Cooper Cobra.
http://www.summitracing.com/search/product-line/cooper-cobra-g-t-tires/wheel-diameter/15-in?N=323532%2B4294920795&SortBy=BestKeywordMatch&SortOrder=Ascending
Then, there is the BFG Radial T/A.
http://www.summitracing.com/search/department/wheels-tires/section/tires/part-type/tires/brand/bfgoodrich-tires/sidewall-style/solid-white-letters/wheel-diameter/15-in/tire-type/passenger-car?N=4294950865%2B4294898494%2B4294898495%2B400073%2B4294897425%2B4294920795%2B4294898460&SortBy=Default&SortOrder=Ascending
Or, how about Mickey Thompson ?
http://www.summitracing.com/search/part-type/tires/department/wheels-tires/section/tires/tire-type/passenger-car/wheel-diameter/15-in/sidewall-style/solid-white-letters/brand/mickey-thompson?N=4294898495%2B4294950865%2B4294898494%2B4294898460%2B4294920795%2B4294897425%2B400206&SortBy=Default&SortOrder=Ascending
But, if you prefer black walls, the choices are unlimited. There's Good Year Eagles, Firestone Firehawks, Toyo, Yokohama, Nitto, etc, etc.
I also like the look of smaller tires on the front, and wider, taller tires on the back(from my racing background I suppose). But, if the front and rear tires are not the same, you can't rotate 'em. :no
For springs, there are all sorts of cheap springs(Chinese I assume), from Summit, Ebay, etc. or you can go with higher priced Eaton Detroit springs.
https://www.eatondetroitspring.com/ordering/parts-lookup/
1 - 2 of 2 Posts
