How to Paint your car for $250
2.6K views 12 replies 10 participants last post by  RamAirThree
WARNING:
This article is bad and not totally acknowledeable, first off he is using an acrylic enamel..... it is not a friendly paint... if a car is painted in acrylic enamel, when time comes for a real paint job you will have no choice but to bring the entire car down to metal and plastics aswell or at least down to the original paint if experienced enough to do so optimally. I repeat Urethanes will not adhere to Acrylic without reactions. This procedure to say at the least will leave you having to invest in an expensive primer/ sealer aswell whether down to bare metal or not. By doing this you will leave yourself open for a can of worms and an expensive reprocussion down the road. Also the grit sand paper is not fully correct and leave you with visible scratches under the finish within months as paint cures. Also if metal is not grinded in a minimal of 36 grit (24 being optimal) you risk body work lift or bubbling underneath the paint. This $250 dollar job would be fine for a daily driver that you care for as nothing more then daily transport that anything would make look better but heed my warning with this when it comes to any vehicle you care for. This is a poor and only temporary fix that I guarantee all imperfections and a peelish poor reflective finish is hidden in pics, that will leave you even more unhappier down the road when the reprocussions present themselves from something like this.
Also putty tends to shrink with curing and will have inferior quality to using a Polyester filler for final body work coat. Certain final coats such as Nitro Stain, spot putty, and Acrylic bumper putties tend to shrink as they cure showing bodywork imperfections through the finish. A prime example of this is when you see a car that has just been fixed and a month or two later and the more time goes by you see rings in the paint outlining the repaired area with filler.
~Lou
Again I stress caution with this.....
Add on: Nelapse also disclosed that the job looked horrible and the car had to be redone and using a better paint from a better company (PPG). I am sure there are other facts left out aswell, guaranteed.
