The hood is flexing a LOT, the metal is so soft. its bouncing for sure. I can see it flexing. I defiantly need some product to prevent it before the next step. Ive been doing body work on this car ..on and off for 2 years haha. so This is my first car bodywork. fortunately the only rust was driver side floor board from leaking t top, and the pan is already replaced.
I have great body lines aside from this hood area to guide me. Heres what Ive done so far, sand to bare metal, pull dents, fill anything large, then shopline epoxy primer, apply full skim of filler, block sand, then i apply another light coat of epoxy primer. I have a gallon and a half of feather fill, to spray and guide coat. then 2k primer and base coat clear coat will be done in a spray booth
I get more pictures on here.
with all the flexing, I was thinking i probably should have tack welded it from the back or something, your recommendation sounds like a great approach. Is it some sort of 3m epoxy?
