Need some help, I should be able to figure this out but thought I would check with you guys before I do it wrong. Put new hood hinges on this weekend and working on aligning the hood. The gap on the drivers side is right at 1/8 inch while the hood to fender gap on the passenger side is about 5/16. Can't quite figure out how to move the hood left to right other than putting a spacer behind the hinge. Also curious when I get the front of the hood down it lifts in the rear. Right now I have the hinges bolted on in the lowest setting. Any advice would be helpful
