9
[Update]
so after, testing, tuning, testing some more, I ran into some Holley Snags
- Holley Sniper throttle bodies come with their internal fuel regulators clogged with metal shavings from the time it was assembled
- the injectors have weak connectors and can come lose from all the vibration, and or it just not being connected correctly at assemble time
these two issues seriously made this install hard, and filled with frustration or not knowing what is causing the nightmare conditions that made me wish I had went with a carb instead
the AFR was consistently wrong and the ECU was doing its best to match the target AFR.This lead to my fuel table being so wrong that it caused unstable idle, temps, and performance.
the injector not working caused the system to over compensate with the other injectors that the system couldn’t stabilize. This lead to rough idle, high fuel consumption, weak vacuum (break booster works so much better now) piss poor performance.
after the fixes were discovered and completed, it’s a whole new car. Breaks work better, the target AFR actually sticks to the Tables, the temp is at 175 whereas it was 190- 210 (to be fair the Fan clutch was on its way out) car is fast again, and the exhaust doesn’t stink like gas (sweet rich smell)
here’s some photo proof and other glamour shots. I’ve also linked the videos that helped me find/fix the issues above.
