21 - 28 of 28 Posts
Ive Got a good one for all of you in the hopes that someone can help solve my problem. Ive got a 94 fire 3.4 L. Turns but dont want to start. I have replaced pump, filter, injectors, regulator. Not to mention Ignition module, coil packs, plugs, crank sensor, cam sensor. timing chain and sprokets. emptied the tank. Still wont start. Security light on, Im going to the key and tumbler. HHeelllppp!
For PASS-KEY problems (the reason your "SECURITY" light is on), read this:
http://shbox.com/1/pass_key.html
Hopefully, the "SECURITY" light wasn't on when you spent all that money on new parts.
Welcome to Firebird Nation.
You should start a new post with your specific problem. Tacking on to the end of a post in the "Resolved Problems" section isn't going to draw the readership that a new post, with the specific symptoms of your problem will draw.
This thread is about "no start" problems. It's in a forum for problems that have been resolved.
If your car is starting, and you are just trying to sort out those codes, best idea would be to start a new topic in the "All Things V6" forum, not the "..... Resolved" forum. More likely to get help with that approach.
Fred / Administrator
21 - 28 of 28 Posts
