Key off, engine off, with no loads i have power back draining the battery.
So far, if I take the red wire off the positive side of the battery, draw goes away. This is the red wire going to the junction box, was removed for some reason.
Following this wire, it goes to a factory "splice connector" with 4 wires coming out;
One goes to the horn relay. Disconnect, no change.
One goes to a little relay on the firewall which has a wire from it going to the alternator. ( One wire set up) Disconnect this and no change.
One wire is black and has a fuse able link. This wire goes into the firewall.
One wire is red and goes into the fire wall.
So, one of the last two wires are the source of the draw.
Then, when i unplug the instrument cluster connector, the draw goes away. This is behind the speedo housing with the printed circuit board. Then one by one, i disconnected each wire from the connector and found that the draw goes away when i pull the white wire from terminal 11, which is the amp wire. Following this wire, it goes behind the fuse box.
Now what???
How do i find why this is happening?
Now what???
