1 - 10 of 20 Posts
Man I wished you would have caught me before I buttoned up mine but
The check valve holds vacuum in the system and the other vacuum switch
Changes normal heat and A/C to vent I hope that helps Eric
Let me look in the assembly manual I think there is a good diagram in there and here is one that is very similar to the 69
Also if you flip the vacuum switch with two lines attached from norm to vent it turns off the water flow.
I have a couple diagrams and I may be able to stick my inspection camera up in there and find out the colored connections
On this one there is a color code in the upper left hand ledger
One is the vacuum supply the other 3 are outputs and i cant get the camera up in there to see sorry
Eric here are some pictures of mine when it was torn apart You might be able to get something out of it
Those are the best i can find if you down load and view them with windows picture viewer you can zoom in on them
And here is a picture of the check valve it goes in the engine compartment
I found some more pictures
The check valve is the vacuum source line the other line goes to the water control valve
Did you get the pictures Eric they were sent
You might have a bad vacuum actuator can or a leak in the control switch
1 - 10 of 20 Posts
