1 - 3 of 3 Posts
Hello, this morning I went and got a coffee it was early so I had my headlights on, when I got back home I flip the headlight switch off but they don't go down so I start troubleshooting. Now I've found that they go up perfectly fine and turn on but as soon as I turn the switch off the fuse blows. Can't find any shorts and I can't keep replacing the fuse every time I want the headlights to go down. Any help would be great. 1986 base Firebird 2.8 V6
First thing I would check is the relay switch then head light switch. Could be a number of things
If you would go to the 3rd gen tech articles, then hit the maser list at top, you'll find the downloadable 88 service manual. While Pontiac made changes between 86 & 88, I believe you'll find that 88 headlight wiring & troubleshooting works for your 86.
1 - 3 of 3 Posts
