1 - 16 of 16 Posts
I would start with a rebuild kit. Changing out the old tie rod ends, ball joints, and control arm bushings. This will cost around $250.00.
Then you might change out the old tired coil springs at $200.00 or less
Then some new shocks, good ones will set you back $100.00 each ish
Try p-s-t.com I used them for 74 Corvette and 87 Monte Carlo SS. There stuff is awesome and they have awesome deal on kyb shocks.
Try this link
http://www.p-s-t.com
Try PST its on internet I used them for 74 Vet I had stuff is awesome. Its polygraphite suspension technologies. The graphite lubes bushings so they don't squeak like polyurethane. Try this link http://www.p-s-t.com
energy suspension polyurethane bushing kit,
Koni adjustable shocks,
stock OR lowering springs
new tie rod ends,
new ball joints,
clean and paint control arms,
check and/or replace center drag link,
check for play in steering box/joint.
All this will be about $500-$600 if purchased through Rock auto and Summit.
Just installed most of my kit. The front feels fantastic, nice and planted.
Partial PTFB GT-pro suspension. Basically everything but the leaf springs. They are on back order so I put a set of 2" blocks in the back to match the front drop. Will need to slightly roll the rear lips as they do touch from time to time.
18x8 4.5" BS front with 245/45-18
18x9.5 5.25" BS rear with 275/40-18
US Mags Rambler
Discussion Starter · #16 ·
Try this link
I wanted to get this rebuild kit but not sure if it comes with everything. tell me what you think? and it gives me an note to choose from Base Or WITH 1.375" LOWER FRONT CONTROL ARM BUSHINGS. and dont know which one to choose and i dont know the diameter of my front sway bar.
SKU: FEKSPCHE701
1 - 16 of 16 Posts
