1 - 3 of 3 Posts
I just put new upper and lower ball joints in my 68 along with Right Stuff disc brake conversion. The top control arm is down so that upper ball joint is at a severe angle. Maybe the wrong spindle? I also replaced coil springs. Any Ideas?
Did you make sure that end of coil springs were seated in the right place on spring seat? Did you compare your old spindles to new ones to see if they were the same basic shape?
I did not check springs to see if they are seated correctly, I will check them. Threw the old spindles away before I compared them, stupid I know !! . Think I will order a new spindle to compare. Thanks for help sea dog!
1 - 3 of 3 Posts
