1 - 16 of 16 Posts
Hello Everyone I hope everyone is having a great weekend I just bought my first 4th gen firebird. I have a 2nd gen i have had for 30 years and a 3rd gen i have owned for 15 but I bought a 4th gen yesterday 1996 formula lt1 automatic drove it 3 hours home ran perfect. the next day i stopped at the gas station filled it up and it right after i left the gas station it died smells of fuel and wont start. I waited 3 hours for it to start and run and then drove it home. I replaced the charcoal canister, the Vapor Canister Purge Valve, the evap Purge Valve, the gas cap, and also a few of the rubber purge lines that were dry rotted. Still having the same issue i have no codes but it is still dying after driving it for 15 minutes or so and it smells like fuel like bad. Any help any one can offer is apricated I am not vary familiar with the evap system on the 4th gen and not sure what to look at next.
· Administrator
Generally the EVAP system does not cause the problems you experienced unless the canister is totally saturated with fuel from overfilling the tank - did you overfill the gas tank? You should stop filling when the pump nozzle shuts off the first time.
The EVAP system can effectively be inactivated and taken out of the equation by taking the vacuum line's rubber elbow off the throttle body and capping the vacuum nipple.
When you replaced the EVAP purge solenoid and adjoining lines, were they wet with fuel? If you replaced the EVAP (canister) Purge Valve on the bracket on the passenger side of the intake manifold, where was the second “evap Purge Valve” that you replaced?
Was the fuel smell predominantly at the driver side rear wheel well, where the canister is located? Or was the fuel smell in the exhaust, indicating an excessively rich A/F ratio? Or was the fuel smell in the engine compartment?
Discussion Starter · #3 · (Edited)
canster
I always hang the gas pump up after it stops so I do not think I overfilled it the other purge value is in the back between the tank and the charcoal canister. no the lines were not wet with fuel when I replaced the purge solenoid. the smell is coming from the hood like it was flooded and from the exhaust like its running to rich and not burning all the fuel. Also I have no codes current. if I plug the manifold and the purge value with vacuum caps will that not cause a fault in the system and wont it build pressure in the system? also could this be the fuel tank vent valve stick closed not releasing pressure? its the only thing in the system I have not replaced.
· Administrator
The valve on top of the tank is a pressure control valve. It opens up to vent excess vapor from the tank to the canister.
The EVAP system is normally closed. It is not controlling pressure in the canister. The vapor from the tank passes through the canister, where the carbon adsorbs the hydrocarbon (gasoline) vapor. The air, stripped of vapor exits an open vent on the canister, into the environment.
Periodically, based on engine RPM, engine load, etc., the PCM opens the EVAP purge solenoid valve. Intake manifold vacuum pulls air through the open vent on the canister, the fresh air removes the hydrocarbon vapor from the carbon, the air/hydrocarbon mixture is pulled by manifold vacuum through the lines, through the EVAP purge solenoid valve, through a passage in the throttle body into the intake manifold. The hydrocarbon gets burned in the engine’s cylinders. If the canister is saturated with liquid gasoline, the intake manifold will be flooded with raw gasoline, and the engine's A/F ratio will be rich.
The EVAP system in never under pressure. If you remove the rubber elbow and plug the vacuum nipple, it prevents the manifold vacuum from sucking vapor or liquid fuel into the system. It will not affect the way the engine runs. All you are doing is temporarily blocking the excess fuel from reaching the engine, IF THAT'S WHERE IT IS COMING FROM. On your OBD-2 1996 it will set a code (P0441 = no flow during purge). That will not cause any issues, and will clear a few drive cycles after you reconnect the EVAP hose to the throttle body.
You are only blocking the vacuum TEMPORARILY to rule out (or confirm) the EVAP system as the cause of the problem.
If the fuel tank pressure control valve sticks closed, pressure can build in the tank, but it will not affect the pressure or flow of fuel to the injectors. There is another pressure/vacuum relief valve on the tank that vents directly to atmosphere, not through the canister.
The next step would be to check the fuel pressure. You will be looking for two problems that can cause the engine to run rich - 1) excessive fuel pressure; or 2) failure of the diaphragm in the fuel pressure regulator (FPR), which will dump raw gasoline into the intake manifold via the vacuum compensation line.
When you are ready to test the fuel pressure, I can give you the procedure and the pressure specifications. Part of the fuel pressure test can be used to detect the leaking FPR diaphragm, or a possible leaking fuel injector.
After the EVAP test and the fuel pressure test, we can look at another possible cause of running rich AFTER the engine warms up - a faulty coolant temperature sensor.
Reactions: 1993TransAm
· Administrator
'93 6-spd Trans Am - '96 C4
Have you scanned the PCM for codes, or is the "no codes" diagnosis based on the Check Engine / Service Engine Soon light not being lit up? If it's the latter, make sure those lights do in fact illuminate during the key-on bulb check. I only bring this up because I bought a car last summer that didn't have a Check Engine light lit, but, when I scanned the PCM for grins, I found a lot of stored codes. One of them informing me the Check Engine light was burned out; which it was. Just a thought.
Reactions: Jpar
Discussion Starter · #6 · (Edited)
Again thanks to everyone who has responded to help me get this fixed.
injuneer
I will check the fuel pressure and test the evap system as you suggested. but it does not seem like it is just running rich because of a bad injector because it runs great until it dies the exhaust does smell like it is running way to rich right before it dies though. or a leaky injector as it has no problems starting. It starts great and runs great for 20 minutes then dies and will not start until you let it sit for an hour or 2. then it runs fine again for another 20 minutes and dies again and will not start and smells of fuel very strong from under the hood. I did check for leaks and can not find any. Also even if somehow it did get overfilled I replaced the canister would that not have fixed the issue if fuel being in the canister and being sucked through the lines was the issue? and if it was a bad injector would it not run bad from starting it and while you were driving it? I mean from the 20 or 30 minutes it runs before it dies it runs great good throttle response no hesitation.
ZumpTA
my code reader shows no codes I will connect my computer tomorrow after work and see what I get. I did check the light is working
· Administrator
I only suggested capping off EVAP to rule it out as the cause. May or may not be the problem. You brought it up as a concern, and indicated you didn’t know anything about the system. I explained “Generally the EVAP is not the cause of the problem…. “, but you specifically indicated the problem started after you filled the tank, and you then started playing “parts replacement roulette” in the hope EVAP was the problem.
If you prefer to just assume it can’t be the EVAP system, move on to the other possibilities. I guess I'm just OCD about using diagnostics in a logical order rather than jumping all over the place.
Good luck.
Discussion Starter · #8 · (Edited)
Good luck.
Let me apologize if that came across as ungrateful thank you for the answers you have provided So I just capped the Manifold and let it idle for 30 minutes it died and wont start again no gas smell this time though also right before it died the idle started jumping around then it died and it wont start. It got to a little above 210 while idling I also never hear the fans kick on should they not have kicked on at 210 it is about 78 degrees outside today here
· DELCO NERD
· Administrator
The first two places folks tend to start with a "no start" condition is the basics: Fuel and Spark.
When the no-start condition is present, is there spark? Yes? Check fuel system / injectors. No? Diagnose Ignition System. You could even spray some starter fluid into the intake while the engine is cranking to see if it lights off. If so, you have a fuel delivery issue. If not, check spark.
When I had a strong "raw" fuel smell from my T/A, it took a while to track down, but I eventually found it. ...under the driver side door the steel fuel lines connect to the Nylon (or whatever they are) fuel lines that run into the engine compartment. 2 are a proper mechanically coupled connection, the other one just uses a rubber fuel line as the coupler. The rubber perished on mine and allowed the fuel vapors to escape to atmosphere. I used 2" of scrap fuel line from my lawn mower in it's place. Problem solved.
The fuel pressure test and observations are important. Engine-off/key-on, it may point to a weak pump, leaking injector(s), etc. Things could also be fine on startup, but at the 20 minute mark you notice fuel pressure fall to ZERO as the engine stalls, and then the pump will not prime again until time passes; and it cools down. ...indicating a "thermal" failure with the pump itself or maybe even the relay.
That said, you might have TWO unrelated problems.
Maybe it's not the fuel system at all, and the fuel smell isn't even related. Maybe it is the fuel system and the smell isn't related...
The ICM has a hand in spark control and is prone to Thermal Failure (after a reasonable service life) due to it's location. It's like a CPU and has a heatsink. Being mounted on the head, it gets really hot, and electronics can only take so much thermal cycling and/or heat before they let go. The thermal paste dries up with age and loses effectiveness...
A failing ICM tends to make the engine cough and spit a bit before it dies in my experience, and once it start this, it doesn't take long before it's just dead 24/7. Two or three ignition cycles at most after the first failure.
Call your local AutoZones and ask if they can bench-test an ICM, one should have the test equipment on hand. They will probably have to heat it to induce failure if it's thermal related.
Or, you can use the Factory Service Manual (or the directions at SHBOX) to test the ICM and OptiSpark in place as soon as the stall/no start condition appears.
The OptiSpark is the Alpha and the Omega of the ignition system; and it can fail from thermals too.
Actually, it seems like only AFTERMARKET OptiSparks fail from thermals. I dealt with this over 10 years and 7 aftermarket Opti's. When my engine got to 160F, it cut off. Dead. No spark until it cooled way down.
There are supposed to be 2 codes for a failed/failing OptiSpark. One code says the high-resolution pulses are missing, this is no big deal, the engine runs fine but can not be timed "as precisely". ...you'd never notice there was an issue if the Check Engine light wasn't lit. The other code, for the low resolution pulse, is major. Without this pulse, the PCM has no idea where any of the pistons are in their stroke. As such, it can't time a spark properly, and could be so far out of time it could damage the engine. ...so the PCM shuts everything down.
Thing is, the aftermarket OptiSparks tend to fail without ever setting a code. They drop their ground apparently, and when that happens, the OptiSpark just "disappears" from the system. No pulses, No codes, No Spark, NOTHING!.
Here is SHBOX's procedure for testing the OptiSpark, and for grins, the coil too:
My first ignition failure was the ICM, but a mechanic said "it's always the OptiSpark when that happens". Opti's were still over $1,200 at GM plus labor so I bought a $500 unit from AutoZone and installed it myself. While the RTV I used was curing, I tore apart the OEM OptiSpark destroying it in the process. Next morning, went to start the engine. NO START! ...this is when I learned of the ICM. Replaced it for $90 and a helluva lot less labor and the engine fired right up. 6 months later, the aftermarket OptiSpark failed. ...and each subsequent replacement failed within 10,000 miles. Always different brands, never a code. Not even once.
Bought a remanufactured OEM OptiSpark almost 10 years ago, never had an issue since. I have replaced the ICM again though. I'd like to think that if I had never destroyed the original OptiSpark, I'd still have it, and would have just replaced the cap and rotor 3 times now.
Point is, do the diagnostics. Even if the fuel smell is actual flooding, you need to know why. Excessive fuel pressure, leaking injector, etc.
Guessing is expensive, and in today's times, the replacement parts likely aren't as good as the near 30 year old parts you'll replace needlessly as you play parts-roulette. As the old saying goes, "If it ain't broke...".
Let us know where you're starting from. Lack of fuel or lack of spark. When you know that, you're on your way to resolution.
If you don't have a multi-meter, now is the time to buy one. Anything around $10 is just fine.
...and if it hasn't been offered yet, member GaryDoug has scanned most of the Factory Service Manuals and provided them to us. It's a great asset. You will need Adobe Reader to search through the document as it's several thousand pages long; and worth it's printed weight in Gold.
The '96 Manual is there. Grab it!
Discussion Starter · #11 ·
Ok tested it after it died I have no spark at the plugs when trying to start it after it dies I replaced the ICM because its only 90 bucks and napa had it in stock it ran for 20 minutes and died again and no spark at the plugs when I try to start it after it died. I did test the coil when I replaced the ICM and it was good but I guess that does not mean it couldn't be failing when it gets hot I think I will just replace it it has 90k on it and it looks original but if that does not fix it I need to test the omni spark next right?
Discussion Starter · #12 ·
Ok so the coil did not fix it. It still died after 20 minutes and then has no spark I am getting a code now though code P0372 i did check the connector for the opti it is dry and the wiring looks good. Is there more testing I can do or does that mean the Opti needs to be replaced?
Discussion Starter · #13 ·
Good luck.
thank you for all the advice you were right was not the EVAP system still dies disconnected, I then replaced the ICM and the coil still same thing it dies after 20 minutes and no spark I am getting a code now though code P0372 I did check the connector for the opti it is dry and the wiring looks good. Is there more testing I can do or does that mean the Opti needs to be replaced?
· Administrator
P0372 is for the high-resolution pulse. In post #10 I explained all of this, including the fact that a missing high-resolution pulse will not shutdown the engine or prevent it from starting. The high-resolution pulse allows for precise timing accuracy. Drop the high-resolution pulse and worst case the engine runs a little rough, maybe even an occasional little backfire, but most people don't even notice a difference. P0372 while a "problem" is nothing serious, or anything that will leave you stranded. Basically, your timing is now as accurate (or inaccurate) as an old-fashioned distributor. Certainly good enough to get the job done, but lacking the precision timing it is capable of.
Failure of the LOW-RESOLUTION pulse will result in the PCM shutting everything down right there on the spot the millisecond the signal drops out. Again, post #10.
Download the Factory Service manual I linked an follow the Diagnostic Flow Chart for your P0372. Section 6E, page 654
If you look the code up online, you will see reference to Crank Position Sensors, Hall Effect Sensors, etc... You don't have any of that. The OptiSpark does the job of these "later" modern sensors. Basically, the code you have is more applicable to and intended for the LS engines, but the diagnostics in the Factory (year specific) Service Manual are correct for you and your situation. ...the things the Internet says to do for this code are NOT intended for you, they are for LS owners.
Factory Service Manual, DOWNLOAD IT and USE IT!
Multi-Meter, MANDATORY equipment!
I suspect you have an aftermarket OptiSpark and it is done; but I hesitate to say that because it sounds like you will just replace the OptiSpark without doing any diagnostics. I had suggested the ICM could be an issue, but also stated how it tends to fail, which is not the failure mode you experience; but you replaced the ICM without even having the free test from AutoZone performed on it. You could have simply Ohm'd out the coil during a failure and seen it was fine/within specification too; but you replaced it anyway.
All wasted money that could have been applied to source of the actual problem.
IF you decide to continue just throwing money at this until it's resolved, get an OptiSpark from Petris Enterprises. NOBODY ELSE. It might solve your problem, it might not; but at least you'll know you have a good OptiSpark you can rely on.
Consider yourself warned... ONLY PETRIS ENTERPRISES. Every OptiSpark on the market now with the exception of Pertis Enterprises comes from China. $500 OptiSparks are no more reliable than $20 OptiSparks these days. Petris builds theirs to a higher specification than even the Factory unit was built to.
Buy anything other than Petris and you'll be here again within 12,000 miles. I promise. There was a time when remanufactured-OEM OptiSparks were the best choice, but lately it appears that some counterfeits and aftermarket units have entered the reman-oem supply chain, so even if you can locate one, avoid it; it's a huge gamble. Petris Enterprises OptiSpark or an LS ignition system conversion are our/your only options at this point. Petris isn't cheap compared to the rest of the market, but they are reliable. Converting to LS style ignition costs about $2k all in, but, that completely eliminates the OptiSpark and also gives you the benefit of on-the-fly tuning with a laptop just like modern cars.
Of course, feel free to disregard everything I have said and buy an OptiSpark from Advance, AutoZone, NAPA, or O'reilly. Just make sure it has a lifetime warranty. You'll need it. You can also look to eBay and Amazon. They have the same Chinese junk at even lower prices. Not sure about the warranty, but I doubt they are "lifetime".
All the major retailers I mention do honor the lifetime warranty, no questions asked, so there's that; and that's worth a little premium.
Good Luck!
Discussion Starter · #15 ·
Good Luck!
Thanks for the advice I ordered the torquehead conversion kit this morning im going to get ride of the opti
· Administrator
If I could afford to, I'd do the Torque Head or EFI Connection 24x conversion myself. Consider me jealous.
Most likely, if you did the diagnostics on the OptiSpark, you'd have found it was bad. No way to say conclusively over the internet mind you, but, I experienced the exact failure mode you are experiencing 8 times in 7 years. It was always the Aftermarket OptiSpark. I was lucky enough to get a reman-OEM OptiSpark from Summit Racing nearly 10 years ago and not a single ignition system issue since; but I still have that doubt in my head every time I drive, "is this the day the OptiSpark dies".
The memory is nearly gone at this point, but the trauma will remain forever.
1 - 16 of 16 Posts
