New to the site here!
Ok so first a little background....
I had a 2000 Formula Ws6, needless to say it got totaled. Anyways i have a lot of money in motor and trans so i found me a 00 WS6 Trans Am roller. Simple right, just throw my motor and trans in there and go. Well no not so simple....lol...Swapped in motor and trans, which wasn't that bad got it all wired up everything hooked up etc etc etc...
Rolls over but will not start, scratch that i have gotten it to run once but it ran like t total butt. But anyways it will roll over and backfire out tailpipe and thats it.
What we have done and checked....
*Grounds, checked all the grounds a million times.
*fuses
*Replaced cam sensor
*Vatts is disabled and pcm is vin matched to car
*58 lbs of fuel pressure at rail
*checked all pins on connectors to make sure harness had no broken wires
*injectors are pulsing
*plugs are sparking
*car ran fine up until we pulled motor
*We have searched and searched and can't seem to find anything wrong.
*Hooked to computer, no codes. crank sensor shows about 350 rpms while turning over on the computer which we didn't replace because of this.
*tach isn't working in the car for some reason. (does this have to do with crank sensor?)
Anyways its been a long time since i have been stumped like this and maybe im missing something small. But i miss my car and tired of looking at it all pretty in the yard...
Everything im finding is pointing to the crank sensor, opinions and help of any kind would be appreciative.
Figured id ask before i threw money at a crank sensor
*fuses
*plugs are sparking
