1 - 6 of 6 Posts
My passenger door tweeter does not have any sound coming out of it. The regular speaker in the door is working fine. I'll be taking the tweeter out and trying it on the driver's side tomorrow, but assuming that it doesn't work on either side does that mean I need to replace the tweeter? I've read that the inline filter goes bad on the tweeters, but I have no idea how to check that or replace it. Can anyone tell me how to do that?
· Ramblin' Wreck
If the tweeters are separate from the midrange speakers, I don't think there are any external filters for the tweeters, but i do think there are some for the midranges. At least, that's what the 94 service manual shows.
· DELCO NERD
There is a capacitor that acts as a high pass filter on the backside of the tweeter magnet.
You will need to remove the door panel in order to get the tweeter out. It's screwed into a metal plate that sits in the tweeter "pod." General Motors also affixes the tweeters to the plate with an adhesive.
What appear to be filters for the midranges in the service manual are likely inductors, which are wired in parallel to the capacitors and are actually second order passive crossovers for the tweeters. The 1992-1995 Grand Am/Skylark/Achieva component door speakers are wired similarly.
I probably should have mentioned my car has the UW2 10 speaker system in my first post and all the speakers are stock.
So once I get the tweeter out, is there anyway to test the capacitor/filter to see if that's the problem? The wires look okay, so I'm assuming it's either the capacitor or the speaker is blown.
Somewhat an unrelated question but do all firebirds and camaro have separated tweeter and "sub" door speakers or was that option? Is there a way to tell if it is an option?
· DELCO NERD
Considering the age of this thread, it is best to start a new topic in the Automotive Audio section.
1 - 6 of 6 Posts
