1 - 3 of 3 Posts
I know there are slight diffferences between the front fenders that can be modified...but are there differences between the 1970-73 door shells and the 1977-81???
On the door shell itself, in 74 GM added the steel beam side protection required by law. I believe the door shells sold by parts vender's will work on 70-76 cars.
But since they are made for 77-81, they may require some modification to where parts like arm rests, window channel parts, etc are mounted.
So my conclusion is; yes it will fit the earlier cars, You may have to use 77-81 window parts, arm rests, etc. If you don't want to do mods to shell.
And since shell has the 77-81 door skin on it, the outer door handle is a little different than your 71.
1 - 3 of 3 Posts
