Hey fellas, (and ladies) I have decided to get the 403 Olds out of the car, even though it's a brand new crate motor with edelbrock intake/carb and Hedman header equipped. There is just too many issues with the main webbing that I have read/heard about and really no sense in throwing a cam or heads on her with those concerns... I am planning to destroke a '77 Pont 400, but have the chance to also get either a '63 389 from a catalina or even a '74 455 from a Grandville as well. I would like to actually use the stroke of the 421's crank and rods, inside the 455's block. I had previously built a (cough,cough) Chevy engine for a friend that was a 327 block along with the 283's crank and rods that would wind up better than any engine that I had ever heard which is why I am considering this. Another reason for destroking is the Pontiac engines make great torque at lower RPM's but aren't usually high revving engines. If any of y'all are Pont guru's or have any direction, would surely appreciate that. I have also considered buying a buddys Toronado and jerking the 350 Diesel block out of it to build a great motor. They have thick webbing in the mains. The engine will be replacing the 403 crate motor in the '79 Trans am which also has a brand new pci transmission and 3:42 rear gears. Thank ya much!
