My "ABS Inop" light has been on for years. ...no biggie really, the front drivers side caliper will lock up under heavy braking, but the car is still compliant.
Today, *every* red light that I stopped at saw normal brake pressure from speed down to about 15/20mph, at that point the pedal drops about 1/2 inch, braking power is severely reduced, then around 5/7mph I get full braking power back and am thrown forward. Durning this time the "low-trac" light lignts up.
I have experienced this many times before, but, once every few months at most. Today, it was every time I stopped.
...also, the "ABS Inop" light is no longer on. I always suspected I had the light because my 3rd brake light is disconneted, I mean, when I swapped out rear hatches, the light appeared. In the past when experiencing the low-trac / loss of brake pressure, the ABS Inop light was still lit.
Wondering if a dirty wheel-speed sensor might be to blame, or, the ABS pump itself.
If it's the pump, can it be "bypassed" somehow? I don't really need ABS and given the systems current state of operation, I don't need to bump into the back of a Mercedes @ 10mph either.
If it's the speed sensors, where is a good source to get a replacement. ...or, is there a preferred method of cleaning them?
1993, LT1, 175,000mi, all OEM from booster to calipers. Calipers are new.
Ideas? Suggestions?
Thanks!
Ideas? Suggestions?
Thanks!
