They aren't too bad but not a quick bolt on job. You have to pop the grease cap off the rotor, undo the castle nut and pin, and slide rotor off. 3 bolts for the shields, the calipers sit in the cutout and not affected. Then just a case of reassembly, maybe some extra grease for rotors and when castle nut just starts to stop the rotor from spinning freely, back it off a notch and put locking pin through. But yes, perfect time to do is when replacing rotors or similar.
As a matter of fact I got lost when I was just originally planning to change the stabilizer bar bushings, I ended up dropping the whole front axle. These dust shields are easy to remove once the wheel has been dropped, and you removed the rotor assembly (just as Aus78Formula said). A bit of paint, some cleaning and silicone grease on the rubber seal, and it's brand new!
Automotive tire Automotive design Gas Automotive wheel system Auto part
Automotive tire Wood Gas Automotive wheel system Musical instrument
Crankset Automotive tire Vehicle brake Motor vehicle Automotive design
