Hi Bryan,
Thank you for your interest. its like trying to solve a jigsaw puzzle.
The 78 diagram shows a 5 port switch hookup and no hookup for the grey hose that goes
to the purge valve. I know there were several changes during the 70-73 years and more later.
Some of the cars had the 9-port valves, some had six port valves and some had 5 port valves.
Some had a second 2 or 3 port valve. I'd just like to know what my car is supposed to have
as opposed to what we found (which may in the end be correct - who knows).
I had a bad vacuum mode switch and thanks to "the parts guy", obtained a switch he refurbished.
After reading a large number of texts on the TransAm site, I am now beginning to understand the
beast a little better and that the switch isn't perefectly tight either. I have vac. tested with a hand
pump the individual vacuum lines (six that I can find) and all are reasonably tight in that they will
hold vacuum to a point and then slowley leak down. When I try hand pumping the lines via the switch
according to the 78 diagram, the only valve that seems to work is the AC on the upper cowl. I can
see the door close with vacuum and open as it leaks down. Can't get the kick panel door to work
either. So I'm now wondering if I'm on the correct ports. I'm also wondering if I'm reading the port
numbering correctly i.e., does the number correlate to the port to its right or to its left???? Egads
man - its driving me nutso LOL.
Here are port assignments supposedly for a 71 AC car that I obtained off the Trans Am site:
Port-1 White (AC)
Port-2 Brown (inside/outside air)
Port-3 Vacuum Source (engine intake manifold w/check valve)
Port-4 Blue Defrost
Port-5 Gray (Purge Valve)
Port-6 Open
Port-7 Yellow (Heat)
Port-8 Open
Port-9 Open
Tomorrow I plan to back the car out of the garage and try the switch per the 78 diagram and see what
works and doesn't work with the engine running and constant 22" of vacuum. If that doesn't do it, I'll go with
the above and see what happens. I did eliminate the rubber plug and now have the lines going direct to the
switch itself. I will also retest all of the lines individually.
Love the car. Had a 70 Ram Air IV brand new and never forgot it. this one is a Formula 350 that at my
76 years is plenty of "giddyap" but the thought of Ram Air IV heads, cam and intake manifold is intriguing
at some point.
Would appreciate any light you can shed on this enigma.
Tonino
