Hi guys, I'm new to the page! I have a problem with my bird. There is no problem when just normally driving around 2000-5000rpm but as soon as i stand on it and it gets around or over 5000rpm my speedo and tach start going crazy. The car runs fine so i wasn't really too concerned but i had it on a dyno a while ago and as soon as it got over 5000 it started doing the same thing and it messed up the dyno reading even. Any thoughts or advice would be greatly appreciated! TIA
lt1 383 stroker
Balanced rotating assembly
218/226 duration 512/512 lift cam
Comp cams 1.6 roller rockers
58mm throttle body intake ported to match
32 lb injectors
Adj fuel pressure regulator
Emissions delete
ECM tuned
Stainless long tube headers
Stainless magnaflow exhaust
Aftermarket tranny cooler
160° thermostat
lt1 383 stroker
32 lb injectors
Emissions delete
ECM tuned
160° thermostat
