And the fit from those Chinesium parts may not be very good.How badly is the existing door damaged (if that’s the reason you need a new door)? There are replacement ”door skins” - the outer surface- readily available. Not cheap though. A salvage part is going to be a lot cheaper, and not require costly grafting to the door frame.
If you take the time to look at the link, at least one of them is “GM Genuine Parts”.And the fit from those Chinesium parts may not be very good.
Appreciate the correction!If you take the time to look at the link, at least one of them is “GM Genuine Parts”.
