I just bought a 94 Formula/TA and it had a Completely rebuilt engine, trans, and new stage 1 clutch, (all had 2900 miles on it when i bought it). also had new tires, rims, and more....
1st issue...
my problem... at startup, 50+ psi oil pressure, at hot idle, after warming up, 25 or so PSI. and never tops out past 40 or so PSI, regardless of 2000 rpms or 5000 rpms. 40 psi is fine for me on that... (yes i know 10psi per 1k rpms, but i'm assuming the release spring is popping into effect at that point.
after driving it a bit, either hard or softly, at idle the oil pressure is bouncing from 20 psi to 0, and check gauge light comes on... i'm assuming bad sending switch... 0 oil pressure would indicate shot bearings, and the machine shop that rebuilt it, is more than reputable, they are the premier engine shop for a long time... and the block they used was a Jester Longblock.
the guy i bought the car from, said the oil pressure had been doing that since the rebuild... and never worried about it. I personally don't like it, and want to fix it... anyone have any other ideas?
2nd issue...
When the above happens... and the PSI starts dropping to zero... my power steering just stops working... unless i rev the engine a hair... 1100 rpms keeps the steering working, and the oil press up... i'm curious at what the heck is going on....
Thanks!!!
Ed.
1st issue...
2nd issue...
Thanks!!!
Ed.
